My D200 and 18200 mm lens and 1224 mm lens have arrived
don_c
The UPS man finally brought what I have been waiting on since the first part of November. It was here waiting on me Friday night when I got home and I am loving all of it. I have a million questions to ask but AM going to read the manual first and ask quesitons later rather than like I normally do..ask and then read.
Hi Don
Congratulations on your new gear. I just finished a 2 week vacation in Mexico with exactly the same equipment, and I must say, that I've never travelled with a more versatile camera/lens combo. Totally I've pressed the shutter 4000 times, and the exposure of the D200 (on aparture priority) never failed once.
The 18-200 is a very ideel lens, good close-up distance, vere effective VR and nice to have a 300mm (eqvi) to frame a stunning sun-set og isolate an interesting face.
I've used the 18-200 on 90% of my shooting, and those shot I made with the 12-24 was inside markets, in narrow streets and in various transportation-vechicle.
In a few weeks i'll put up some of the results from Mexico on my website: http://www.photos4u.dk
Ole Bo Jensen
www.photos4u.dk
Hi guys: I have been using the D 200, 18-200 VR Zoom for about 3 weeks, and have shot abouyt 400 pictures. MOST of the photos are not sharp, without using photoshop sharpening. Yes if you want a 4x6 print they are fine, but if your gonna go to 13 x 19 you got a problem. I have been shooting the finest JPEG at the highest resolution but the results Not critically sharp. I wonder if its the Lens,camera,me or a combination.
Try some using a tripod. One of the prime destroyers of sharpness is camera movement. It will reduce the sharpest lens and most accurate focus to mush.
In 35mm photography, there is a rule of thumb on shutter speeds. The minimum speed one should attempt to hand hold is 1/focal length. Therefor if one is shooting with a 200mm lens, anything below 1/200th of a second gets chancey. Since the D200 has a 1.5x cropping factor, that would translate into 1/300th for a 200mm lens. Obviously, the longer the focal length, the more difficult it is to hold the camera perfectly steady. The VR lens should grant you at least two or three EV slower shutter speeds with VR working. However, it has its limits too.
It is the nature of digital imaging that sharpening is pretty much universally required. The sensor is a mosaic of tiny photosites usually with red, green and blue filters. They read the colour information for each pixel from slightly offset positions, plus there is generally an anti-aliasing filter over them. With film, all colours are read by layers sensitive to red, green and blue. Since they are layers, they read the colours at the same axis spot relative to the film's dimensions.
I really have never liked the sharpening built into any camera I have used, or any scanner for that matter. I keep it turned off, and apply it to images in Photoshop, optimizing it for the needs of the individual image. I get very good results in Lab colour mode.
Lab mode deals with lightness and colour independently. If one sharpens in RGB mode - in camera or in Photoshop - it tends to put bright desaturated haloes around detail and the picture looks "sharpened" rather than sharp.
Go into Lab mode [Image->Mode->Lab Color].
Select the Lighness channel either from the Channel Palette or by hitting [Ctrl+1]. You should see a B&W image.
Select the Unsharp Mask filter [Filter->Sharpen->Unsharp Mask] and set the threshold to zero, the radius to 0.25 (yes, sub-pixel level) and the amount to the minimum to make the image look sharp. This is generally between 100 and 500 depending upon a whole slew of factors. Use the least that will do the job. Return to all channels either through the palette or [Ctrl+~]
Film accutance is defined as edge contrast - it is what makes film look sharp far more than high resolution. This closely resembles the look of accutance and makes the image look sharp rather than sharpened. Since you sharpen ONLY the lighteness channel, the colour channels retain their colour and saturation.
This method will not save a shot with terminal motion blur however, though it may help a bit. The key is to keep your shutter speeds up when shooting on location. Use a tripod or monopod as much as possible, and if not possible try to rest your hands on something or even lean against a wall, post or tree for added steadiness. Do careful testing with the VR lens, to determine what the actual limits are at various focal lengths. In fact the first thousand or so shots with a new digital body should be devoted to testing and fine tuning the settings to your preferences and requirements.
Always be aware of your shutter speed. Over the decades unless shooting with manual cameras, I have shot almost exclusively on aperture priority, which will always give me the highest possible shutter speed in any situation. Even so, I am always aware what the shutter speed is.
larry!
http://www.larry-bolch.com/
ICQ 76620504
Hi Ed
Sorry to hear about your problems. I have now taken 5000+ pictures with the combo with no problems.
I wonder though, if this is your first D-SLR and if you are used to compact digital cameras. I ask you because I myself had a similar problem, when I entered the D-slr world (D70 + kit) after having been using a Coolpix 5400.
I then asked myself and others why the images from a D-slr was more blurry than of the CP-5400. Tha answer I got was that generally the D-SLR images was less sharpened than from the more camera-to-printer oriented Coolpix, and that the usage of the pictures from a D-SLR often would need post-processing to get to their finest of presence.
1. Try shooting in RAW, there is a very big difference in the way Nikon Capture processes your images compared to the built-in computer.
2. Set the camera sharpening to high.
3. If this doesnt work, send me an image and I'll evaluate the result compared to my own combo.
Ole
Don:
When following Larry's good advice, be sure to turn off the VR when using a tripod.
Good Luck:
Gilbert
Thanks Gilbert I will do that but this time it wasn't me that was having the problem. I did read what Larry had to say and it made a lot of sense however.
I have read that you should use the unsharpen mask for better images at the camera level. My D200 is sharp w/ the 17-55, but the colors are a bit muted ... which is fair since I am just using the "normal" color capture mode w/ adobe colorspace.
This shot is straight from the camera w/ no corrections. Taken at 5.6, 1/20th with a tripod ISO 100.
Michael.
Darkroom 101 says that every shot should have at least a little white and a little black for reference. In practice, this is not always the case, but most images need a full dynamic range or they look dull. In this case, your highest luminance value is only around 220 out of 255. There are a few specular highlights in the 220 to 255 range which need to go to pure white anyway. Setting the luminance for about 225 makes the picture come alive. A slight bump of the gamma opens up the shadow areas and does away with any harshness. A bit of added saturation will also help.
This is NOT something the camera should do. The subject was of limited contrast range and the camera reproduced it accurately. Film would have provided similar results. This is what you want. It is an excellent exposure - an ideal starting point for fine tuning in Photoshop or your image processor of choice. Image processing and shooting are simply the inseperable two sides of the same coin and have been, since Fox Talbot make the first negative/positive print 170 years ago. Some things are best done with the camera, others in processing.
Photoshop should not have to make major corrections, but simply fine tune the image, as in this case. No different than working in the fume-room. The key is to get excellent exposures such as this on site. When shooting, concentrate on the capture of the content at this quality level. In the digital darkroom, you have the time to contemplate and refine the image. In musical terms, Ansel Adams stated it so well: "The exposure is the score, but the print is the performance". In this case, you have an excellent score to perform
As I stated in an earlier message, I really don't like the look of in-camera sharpening. It uses RGB and tends to look phony. Doing it in the digital darkroom allows one to fine tune it to the needs of the individual image. In many cases, I do not do sharpening globally, but in the case of a person of mature years, may confine it to the eyes, eyebrows. teeth and hair.
larry!
ICQ 76620504
Larry,
Great comments. Thanks. When you said "your highest luminance value is only around 220 out of 255.
the picture come alive", what tool did you use to determine the range? Photoshop?
Yes, this was the original image w/o any photshop changes. I made a 2x3 foot print which was very sharp, running it throug Genuine Fractials to produce a 200 megabyte file. I only slightly bumped the contrast to give it a bit more "pop".
I also have always resisted "sharpening" in the camera and leave it to photoshop. I read a review which did, though suggest better results using the unsharp mask in the camera.
Thanks for your comments.
Michael.
