sigma 150-500mm problem
alan2
Hi all, I have a 150-500mm apo with image stabiliser. It is quite noisy when the image stabilser is activated, making like a motor running sound and a click after a couple of seconds when it has finished. It works fine, just irritatingly noisy.... anyone else had this problem? any cure?
All of the OS models will have that noise it the motor...if you think it is too excessive...contact Sigma...and let them take a look at it...make sure you send it with a copy of the reciept...
I have an 80-400 and 50-500 that is quite noisy also...
Tony C. :z04_cowboy:
When using OS, my 120-400mm makes a clunking noise after focusing. When using the camera outside, the noise from the lens is barely audible; but that's probably because the shutter noise from my canon is enough to wake the dead.
